trans wont shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 10:01 AM
trans wont shift
Last fall while on a rod run my hotrods accelerator stuck wide open. Thanks to everyone on the forum that problem was diagnosed as a broken motor mount. As a result of this my my transmission will not shift out of first gear therefore im topping out at about 50 mph. From doing research it sounds like the filter needs changed or the gear is bad or the governor is bad. Do all of this sound like the solution is to repair or change these
Old 04-21-2013, 11:27 AM
Pull the governor out 1st. Jack up the governor side of the car and you should loose much fluid but you still should have a dan pan under it. I wouldn't pull the pan off until you check out the gov.
Old 04-21-2013, 11:47 AM
what would i be looking for a gear that might be bad
Old 04-21-2013, 10:14 PM
It will be stripped or more likey snapped off if it's bad. If anything is preventing the flyweights from moving that will cause a no shifting problem also.
Auto trans wont shift when cold Torque454 Transmission - Rearend 6 02-07-2012 04:54 PM
T-350 trans wont shift out of 1st stanjr41 Transmission - Rearend 4 12-31-2011 10:39 AM
350 turbo trans wont shift targettracer Transmission - Rearend 3 07-06-2011 11:49 AM
700r4 trans that wont shift to dr or od emyers Transmission - Rearend 3 03-19-2011 04:51 PM
T-350 trans, it wont shift jettajo42 Transmission - Rearend 1 06-15-2008 11:05 PM
