Transaxle Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2003, 06:49 AM
Yes, transaxle as in FWD. Stop reading now if chatting about FWD makes you want to hurl.
I've searched the web and come up with nothing on this, so I thought I'd try here. I discovered last night that my Allante has "junkyard writing" on the transaxle, making me suspect it has been replaced.
The Allante originally came with the F7, which was a beefed up 440t4. Later the 440t4 was revised and became the 4t60, and then later, the 4t60e.
Externally, it should be easy to tell a 4t60e from the rest, but how do you differentiate between an F7/440T4/4T60 if you came across one in the junkyard, or someone offered it for sale (or you found it in your car)?
Any help would be much appreciated.
Old 06-18-2003, 06:26 PM
Crosley's Avatar
Wiki Edits: 1659
the 4T60E has a round electrical connector about 1.25 inches in diameter with about 12 wires to it.
the others have small square shaped conectors, about 3/4 inch in size.
Old 06-19-2003, 11:46 AM
67 Nova 400sbc.4L60
F7/440T4/4T60
Just record the original Model number from the Metal tag and search for the same model . Example 7ACH This happens to be 1987 Cadillac
