Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - transbrake basics
Old 06-24-2006, 09:50 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
I'll mention one item here;
Most transbrake transmission operates at higher main line pressures since it is a racing tranny.
Higher pressures mean more wear on the pump and more heat is developed.
I would not suggest a trans brake transmission for street use.
Which transmission with a transbrake are you thinking of installing?
