Transbrake Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2011, 02:33 AM
Hello, was just wondering if anyone here was familiar with transbrakes and/or use them in their hotrod. I have a quick question about running a transbrake setup and how to go about it.
I have a TH400 with a transbrake and a manual reverse valve body and was thinking about installing it in my 87 camaro with a 383. My question was what precautions/ upgrades should I make to the car or drive train to handle the durability required to use a transbrake? Stall converters, driveshaft, axels ect...
Thanks!
Old 08-31-2011, 06:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Typical trans brake valve bodys operate at higher pressures than street valve bodys. The shifts are very firm and firmness of the shift will depend on the stall speed design converter you need for your combo.
A larger trans oil cooler is often suggested too , again depending on the converter stall and your combination
Should I run a transbrake? zildjian4life218 Transmission - Rearend 6 10-30-2009 10:59 PM
Transbrake installation questions S10 Racer Transmission - Rearend 2 11-02-2008 05:38 PM
transbrake dennisb Transmission - Rearend 2 04-30-2006 11:39 PM
Transbrake? oldschoolrods Hotrodding Basics 6 02-12-2005 03:09 PM
transbrake shagginwagonvic Transmission - Rearend 6 05-07-2002 09:07 AM
