Transbrake Solenoid Stroke - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2012, 01:20 PM
Does anyone know who makes a transbrake solenoid for an aluninum powerglide with a .335 stroke -can't seem to find one and the wire broke off on mine- any suggestions?
Old 01-13-2012, 01:58 PM
WDCreech's Avatar
Grumpy Old Goat Herder
I would get hold of the manufacturer of that valve body.
Old 01-15-2012, 02:47 PM
Transbrake Solenoid
Thanks for the comeback. I'm trying to figure out who built it without pulling the pan off. Maybe I'll try & post a couple pictures...........................Gus
Old 01-15-2012, 02:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there are a few variations on solenoids used. Some completely different in length of pin stroke. Photo would help to ID what you have.
It would be best to have pan off to verify the proper operation on the solenoid and to verify the valve is moved fully each direction
square bore/stroke and high rod/stroke ratios blight Engine 29 01-19-2012 11:46 AM
PG Transbrake eight90 Transmission - Rearend 2 05-14-2008 11:23 PM
Something different... A 4-stroke that uses 2-stroke oil in the fuel... Bumpstick Engine 1 06-03-2007 09:45 AM
Compression stroke vs. Exhaust stroke hgufrin Engine 3 03-23-2007 01:43 PM
short stroke VS long stroke pool brian12c Hotrodding Basics 43 06-07-2005 04:40 PM
