Transbrake & Torque Converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2007, 12:36 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I have a TH400 Race Built Tranny to 900HP. I was wanting to know if there is any performance advantages of using a stall convertor if you are using a transbrake. A transbrake allows you to reach the desired RPM before launch so I do not see any advantage of having to use a stall convertor. Any tips or suggestions would be welcomed. Thanks
Old 11-22-2007, 02:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you must be new to drag racing , torque converters and trans brakes.
The engine will not reach a desired RPM for a launch with a trans brake unless the converter is built to allow the extra stall speed RPM.
The converter needs to be built a bit stronger for trans brake operation too. Anti-balloon plates are usually added
Old 11-22-2007, 08:05 PM
WDCreech's Avatar
Grumpy Old Goat Herder
To add to Crosley's reply, for optimum performance, the engine needs to run at, or near, the torque peak to the horsepower peak. If you were to leave a converter in, that had too low of stall, the engine would probably bog on the launch and wouldn't have its potential power after each shift. Of course, having a lot of power, at the launch, may present traction problems, but that can be worked out too!
Torque converter question sam83k10 Transmission - Rearend 7 08-09-2007 08:23 PM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 01:46 PM
Leaky torque converter?? 84Z Transmission - Rearend 6 03-04-2006 06:17 PM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 12:41 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 09:52 PM
