transfer case - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2012, 10:15 PM
transfer case
ok ill start off by saying i have a 1979 chevy k10 with a 350 and th350 trany i have a np203 and that is what i have questions about, when i was workin on my truck i noticed that the rear cover that the speedo cable plugs into is different from all the pics i have seen on line. my speedo cable plugs in on the passenger side and all the pics i have seen its on the drivers side, so i took it off and fliped it upside down but now the vent hose is on the bottum and leaks alil oil. im so confused any help would be great i dont know what to do thank you.
Old 02-09-2012, 12:31 AM
Wiki Edits: 85
Reinstall it with the vent up.
Old 02-09-2012, 01:22 AM
But then the speedo port is on the wrong side is it not I have gone through like 5 speedo cables
Old 02-09-2012, 06:13 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The vent must be in the up position.
The speedometer cable does not know what side the cable attaches to : drivers or passenger side. All the cable does is spin.
I suspect You have another problem that is causing the cable to go bad. Too tight of angles, speedometer head problems can damage a cable
np 203 transfer case tgbulger2 Transmission - Rearend 1 02-12-2011 10:24 PM
Transfer case not going on. Raybob Transmission - Rearend 10 12-15-2008 08:27 PM
transfer case dbarnes Transmission - Rearend 2 09-16-2005 08:26 PM
transfer case help 53fordguy Transmission - Rearend 4 03-19-2005 11:54 PM
