Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transfer case - NP 203 - 205
Old 03-24-2006, 06:50 AM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
I will only directly bolt in if it came from another TH-350, and you have the correct adapter plate and shaft sleeve. If so, the shifter will fit into the same hole in the floor and you can use the same shifter boot.
The front driveshaft "should" fit just fine, and I am unsure about the rear.
