on transfer case conversion question
We are also converting a np 203 to an np 205, 32 spline. Where do you get the adapter kits for a GM 203 to 205? thanks for the advice. c
Last edited by M&M CUSTOM; 03-08-2009 at 05:48 PM. Reason: Copy-pasting. Please see: copy-pasting guidelines. |
Adapters for any "racetrack" type 205 are expensive and hard to find because they are old and lots of them have broken over the years and have been replaced. The later round style is also hard to find mainly because of a limited production run.
you will need to do lots of junkyard and online searching to find al the parts needed to convert from full to part time
this is why most ppl just put part time hubs on the full time trucks because its just so much $ and trouble to convert because you have to swap so many parts over you practically need an entire donor truck i have a th400 205 1980 k20 truck out back sitting in the woods if you need pics of the correct crossmember and adapter and so on of course 400 spline are different than other trannies and henceforth the transfer case as well 32 spline was most or all th400 83 and up or so was a new W-shaped crossmember and a spline count change too for some of the trannies and cases, such as the CH465 4 speed manal trans which changed from 10 to 32 spline(same as th400) i had an 83 K20 like this i drove for a year and it was a great truck. it gets pretty complicated and confusing to most ppl in short order. so.. 205 32 spline: ![]() 400 and 205: ![]() 400 to 205: 85-up 400 and 205: ![]() this page of pics and descriptions: http://www.justchevytrucks.com/truck...sfercases.html good luck Last edited by fast68; 03-09-2009 at 12:57 AM. |
If you are talking all 400s, regardless of application, there is a 4x4 10-spline output specifically for late 70s Jeeps with QuadraTrack transfer cases and a 27 spline 2wd output for the 9" extension housing. The last is officially called a 375THM, but except for the tail and shaft, everything is identical to a 400. |
