Transfer slot help Quickfuel SS750 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2012, 12:46 PM
Joe428's Avatar
I am trying to set my transfer slot to the square range of .02-.04 but i have my curb idle backed all the way off but my slot is still too exposed no where near that.
Quickfuel SS750 mech sec
Old 02-15-2012, 01:15 AM
Joe428's Avatar
[IMG][/IMG]
Mine is in this ballpark maybe a tad longer. I just keep hearing to get it square.
Old 02-15-2012, 01:34 AM
Joe428's Avatar
I'll measure tomorrow to see where I am. I just figured it was to exposed already so I didn't bother measuring it.
Old 02-16-2012, 03:18 PM
Does this carb have a choke on it? If it does and your trying to set your transfer slot with out the choke open it will be on the fast idle cam. If it is just hold open you choke plate all the way and then let the throttle come off the fast idle cam and make sure you hole it then turn it over and you will be able to set it just right. Hope that is what your issue is something simple.
Eric
Old 02-16-2012, 10:40 PM
Joe428's Avatar
Wow I totally forgot about that ill check it out tomorrow. Thanks for the reply Eric. Hope it is this simple too.
Old 02-16-2012, 10:49 PM
Joe428's Avatar
Yep it was the choke all along thanks so much Eric.
Old 02-18-2012, 05:02 PM
Hello glad I was able to help you out and glad to hear you got it ok. Well take care and good luck on your build.
Eric
Pro systems dp vs Quickfuel vs Holdon Engine 26 03-03-2012 10:53 AM
Holley 4150 transfer slot leak bigvinnie Engine 4 12-30-2009 06:37 AM
Holley idle/transfer slot adj question Argess Engine 8 09-11-2009 02:54 PM
New carb Street HP Proform QuickFuel tomthecomic Engine 1 02-25-2009 08:13 AM
idles perfect but cruise is lean..enlarging transfer slot restrictors? darkostoj Engine 0 06-25-2008 08:49 PM
