Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - transfer slot setup
Old 09-30-2012, 08:10 AM
cdminter59 cdminter59 is offline
transfer slot setup
That MSD Streetfire Distributor has got your head messed up. But anyway you are adjusting the transfer slots right. They both should be adjusted about .020. Get rid of the Streetfire distributor and get the MSD-8360. It has the bushings you change to adjust the mechanical advance. I think the vacuum advance is the same setup as your Streetfire.
