transfer slot setup - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-08-2012, 10:22 PM
painted jester's Avatar
Last journal entry: 383 BLAH, BLAH.
Originally Posted by ggevaert View Post
Hello,
Painted Jester, that is one of the articles I have followed when building my own procedure. I have not yet gone as far as modifying the PCVR's, jets, PCV's, etc as I want to work through where I'm at first (once I drill there is no going back). Next step is the air/fuel mixture but first I need a stable idle based on idle transfer slots. Based on what I've been reading I should be ok but, like Cobalt327 says, there may be other factors involved I will need to study up on.
Thanks and keep the information coming!
Gary
I didnt mean to do everything in the article!!!LOL
It has a section about the idle slots and good info to help you understand a little about the other circuits !! You asked about your converter not being loose enough What that meant? I took for granted your knowledge is limited !! And your asking questions about the carb that are very basic ( no insult intended )
And once you drill the P.V.R. you can go back by installing a screw in bleed and drilling smaller ! ( not that you need that) But it tells me you didn't read the article very well or it didn't sink in!
Jester
  #17 (permalink)
Old 10-09-2012, 10:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by cobalt327 View Post
0.020"-0.040" is the baseline setting (about square, or open as far as the slot is wide). It is not at all unusual or incorrect to have the primary transfer slot at 0.040"- in fact that's more common than less if there's any kind of performance cam involved. The baseline for the secondaries is almost closed, then open as needed to get "bypass" air.
I should point out that the secondary bypass air is used only if the primary side cannot be adjusted to give a good idle by using the idle mixture screws and the curb idle screw.
If you have to open the transfer slot too much w/the curb idle screw- THAT is when you start to use the 2'ndary side to add bypass air to get the idle right. This is preferred by me to drilling holes in the primary butterflies. But this isn't required unless you have a fairly radical cam- so what are the cam specs?
  #18 (permalink)
Old 10-09-2012, 09:07 PM
ggevaert's Avatar
t-slot setup
Hello,
Well, the other thread was supposed to stick to just distributor type questions (re: mechanical and vacuum) and this one about holley type stuff but there is some overlap going on.
Anyway, that's why I'm here and asking questions, some items I'm fairly familiar with but others are new hat.
My cam is a Comp Cams 450 lift, 224 duration, 206 lobe centre. I had it running good at 800 idle with just primary screw adjustments but when I looked at the t-slot after pulling off the carb it was pretty large (didn't measure or write it down as I was going to go through the 0.020" setup procedure anyway). I will, for the record, reset the secondary to closed, adjust the idle with the primaries to 850 and then pull the carb and read the t-slot size.
The part I was trying to understand was the proper order of things when modifying a holley and then, in turn, doing each of these to ensure you have a properly running engine. I do understand there is some level of going back and forth but there must be some items that have to be done in order to get them correct. For example, you would never setup a holley until your timing is good.
Here is the list I have sofar of steps and the order they should be done in.
1. Get the timing fixed and correct
2. Verify that you have 4-7 psi of fuel pressure; ensure it is NOT higher than 7.5 psi as that can cause severe fuel control problems
a. If too high then install a fuel regulator and set to proper psi at 6.5 psi
b. If not enough then you need to replace the tank intake, pump and all the lines as they could be clogged.
c. At high rpm or WOT fuel pressure should not drop below 3.0 psi; if it does you need a higher volume fuel pump.
d. Ensure that the fuel filter is the large one and does not come close to heat or in contact with the engine itself. A large filter can transmit a lot of heat to the fuel.
3. Ensure you use a large 14"x3" open element air cleaner; it will offer very little resistance to air flow, thereby not causing the fuel to go leaner. All Holley carbs are initially calibrated using this type of air cleaner.
4. Check for manifold-to-head and manifold-to-carb vacuum leaks
5. Take out the Carb and take it apart. Write down:
a. Jet sizes
b. Actuation point of the power valve
c. Size of the accelerator pump squirter
6. Get the floats right
a. Primary with the level just barely below the sight plug, secondary the fuel level about .050" below the sight plug
i. My carb (Holley 600 w/vacuum secondaries) does not have adjustable so must leave as is
7. Make sure venturi butterflies and the choke plate open fully
8. Set the transfer slot as per procedure below
9. Set Idle mixture as per procedure below
10. Check off-idle circuit (tip-in) as per procedure below
11. Set your power valves as well as your PVCR’s as per procedure below
12. Set your jets as per procedure below
13. Tune your secondary’s
14. Set your accelerator pump
15. Set your fast idle setup (for when choke is on)
Where it says 'as per procedure below' I then have detailed steps (with pics) on how to do that from what I have learned (both from reading and by experimentation). I did read a lot of articles from reputable companies like Holley (which has a whole technical library) to car magazine articles and where I found corroboration then I put that in my procedure. If you want to read it let me know and I'll upload it for you to see.
Sooo, long story short, when I set the primaries to 0.020 and the secondaries to 0.020 then my idle was at 2200 with the fast idle off so then i adjusted the secondaries to give me an idle of 1050. I think I was closing them off slowly, can't recall right now.
It sounds like my next steps now are:
- close down secondaries and run engine to see what happens with tslot on primary set only at 0.020"
BTW, my idle air screws are currently reset to 1.5 turns; when I tried to work them before I did my t-slot adjustment they did nothing. no increase or decrease in vacuum until I stalled the engine going all the way closed so I left them and started at the t-slot procedure.
Sorry for the long email
Thanks
Gary
  #19 (permalink)
Old 10-11-2012, 01:16 PM
What model# carb are you modifying? Is it a Holley or a copycat? ( like Quickfuel? ) Is the carb new or used? And for what purpose Street, , Roundy Round, Drag Etc? Does it have to be class legal?
Maybe you mentioned it and I missed it? Or maybe you stated it on another thread I haven't read?
Jester
  #20 (permalink)
Old 10-11-2012, 02:37 PM
transfer slot setup
Jester, he has a Holley 600 w/vacuum secondaries.
  #21 (permalink)
Old 10-11-2012, 02:45 PM
Universal with a ford passing gear kick down? basic street carb no needle & seat adjustment except for bending the float arm?
  #22 (permalink)
Old 10-12-2012, 02:19 PM
ggevaert's Avatar
Holley
Correct, relatively new (about 1.5 years old) Holley 600 w/vacuum secondaries. No adjustment possible on floats, needle or seat. has air/fuel mixture adjustment.
Has the provision for the ford kickdown (which I just found out in another thread where I asked what the lever besides the throttle was for).
Put the Holley work on hold until I get the 2500 stall 10" converter (current was 1500) in early next week. That should help with my stall problems (as noted by F-bird'88 in my other tread on the distributor).
Thanks
  #23 (permalink)
Old 10-13-2012, 10:27 AM
ggevaert's Avatar
Holley
Just to answer Painted Jesters other question, this is for the street. And it doesn't need to be class legal. Truck does not get a lot of miles on it so not a daily driver; more like an experimentation/learning tool and fun driver.
Thanks
  #24 (permalink)
Old 10-13-2012, 04:04 PM
Thanks
Jester
Transfer slot help Quickfuel SS750 Joe428 Engine 6 02-18-2012 05:02 PM
Holley 4150 transfer slot leak bigvinnie Engine 5 12-30-2009 10:10 AM
Holley idle/transfer slot adj question Argess Engine 8 09-11-2009 02:54 PM
Slot Cars cobalt327 Hotrodders' Lounge 12 06-22-2009 03:21 PM
idles perfect but cruise is lean..enlarging transfer slot restrictors? darkostoj Engine 0 06-25-2008 08:49 PM
