Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transgo 1-2 shift firmness T-350
Old 01-20-2013, 10:01 PM
pricesgarages's Avatar
pricesgarages pricesgarages is offline
just remove the 1-2 accumulator spring on the side of the case if u have a adjustable modulator turn up the line psi is the kickdown cable hooked up and are u running a high stall converter that will make the shifts solfter
