transgo 1&2 for th350
Will this th350 1&2 let me shift from 2 to 3 at any rpm? Or do I need a auto/manual tci valve body?
no and the auto/manual v-body will not either. The TransGo 1 & 2 shift kit is the same as the manual / automatic v-body from any manufacturer. The manual / auto v-body name is some what misunderstood. the v-body will shift automatically up and down. You can hold a gear to desired RPM for shift. You can down shift to 1st gear at any RPM. You can NOT upshift at any RPM.... the governor will over ride / not allow that up shift. you would need a full manual shift v-body to shift when and what RPM you want.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
thank you
Boy would I have been disappointed to say the lest. The manual on the street does not sound like fun.
| No 4th Gear After Transgo JR Install 700r4 | weigesco | Transmission - Rearend | 3 | 05-03-2007 12:52 PM |
| Transgo Mod - Rear Servo Washer Stack | 68NovaSS | Transmission - Rearend | 4 | 09-03-2006 06:17 PM |
| 700r4 shifting problems with transgo kit | mb9900 | Transmission - Rearend | 18 | 08-14-2005 08:20 PM |
| TransGo 700 Performance Shift Kit Problem | edge | Transmission - Rearend | 1 | 08-02-2004 12:47 PM |
| shift kits, b&m vs transgo? | Dubz | Transmission - Rearend | 8 | 09-16-2003 01:09 PM |
