Transgo 700 2-3 kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2007, 06:42 PM
happydad's Avatar
Transgo 700 2-3 kit
O.K. I understand the manual or leave it in drive shifting stuff,,But what if ya want to eliminate the TV cable ?? Do I have to go complete manual valve body???
Old 08-18-2007, 07:12 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yep...
you will need to shop around as many manual shift valve bodies retain the TV cable for main line pressure control
700r4 shifting problems with transgo kit mb9900 Transmission - Rearend 18 08-14-2005 08:20 PM
which is the best overhaul kit 403pontiac Transmission - Rearend 2 05-25-2005 07:50 AM
Transgo Shift kit "stick mode" 700r4 eliotmansfield Transmission - Rearend 11 05-03-2005 08:22 AM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
383 Stroker kit on Ebay any good? sb72elcamino350 Engine 1 03-04-2004 08:02 PM
