Which TransGo kit for TH350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2008, 06:56 AM
Hi all,
I'm just finishing up the rebuild of the TH350 and need to procure a shift kit. I see TransGo has a "shift kit" and a "reprogramming kit". I want firmer shifts but also the kit that dual feeds the directs and all the little tricks. This is going behind a 350-ish HP 350 in a 36 Ford. I see the 350 -1&2 kits and know I don't want the -3 kit. Help??
Thanks,
Cam
Old 02-13-2008, 07:47 AM
350 turbo
Ya l've always used the B&M stage one, its great $57 Canadian,but you'll have to shift yourself if you take the mod valve out and it hits real hard if you got your rpms up, but you can leave the mod in you can shift it yourself or let it do itself , also with this kit you can change the chalk balls around to feed the oil wherever, you just need to know what your doing
Old 02-13-2008, 08:03 AM
1952_Chevy_Panel's Avatar
Money pit
I've heard good things about the B&M kits, plus you can get them at the local Advanced, in the performance section.
If you're set on a Transgo kit, call them 1-626-443-7451
transgo reprograming kit pink63impala Transmission - Rearend 9 08-27-2005 10:10 AM
700r4 shifting problems with transgo kit mb9900 Transmission - Rearend 18 08-14-2005 08:20 PM
which is the best overhaul kit 403pontiac Transmission - Rearend 2 05-25-2005 07:50 AM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-23-2005 11:25 PM
383 Stroker kit on Ebay any good? sb72elcamino350 Engine 1 03-04-2004 08:02 PM
