Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transgo Mod - Rear Servo Washer Stack
Old 09-01-2006, 09:55 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
reassemble the servo setup as OE........ use it.
always check the bores for wear from the sealing rings...... correct if there are ridges.
