-   -   TransGo reprogram kit (http://www.hotrodders.com/forum/transgo-reprogram-kit-218433.html)
PontiacFighter 04-21-2012 07:34 PM
Hey guys, I know there's a lot of info out there but I just can't find any clear answer to my question. I'm looking into buying a TransGo reprogramming kit for my TH350. I know there is a 1-2 kit and a stick kit. I am confused as to how they work. Will a stick kit require me to constantly shift through gears like a manual? Will a 1-2 kit make it shift harder and crisper while still allowing me to put the transmission in "drive"? Can you please clear this up for me. When it comes to trannys I'm not up on all of the terminology.
rick 427 04-21-2012 10:32 PM
the answer to your 2 questions is yes....and yes
PontiacFighter 04-22-2012 08:48 AM
So the 1-2 kit will only improve my shift quality?
rick 427 04-22-2012 11:34 AM
It will,as well as improving oil flow along with the firmness of the shifts..thats assuming that the trans is in good working order before you install the kit... ....It's a very good kit....you will have full manual control with the trans...and if you just leave it in D..it will shift automatically.
PontiacFighter 04-22-2012 03:15 PM
Ok thank you
