TransGo reprogram kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 07:34 PM
Hey guys, I know there's a lot of info out there but I just can't find any clear answer to my question. I'm looking into buying a TransGo reprogramming kit for my TH350. I know there is a 1-2 kit and a stick kit. I am confused as to how they work. Will a stick kit require me to constantly shift through gears like a manual? Will a 1-2 kit make it shift harder and crisper while still allowing me to put the transmission in "drive"? Can you please clear this up for me. When it comes to trannys I'm not up on all of the terminology.
Old 04-21-2012, 10:32 PM
rick 427's Avatar
Last journal entry: The Cheetah
the answer to your 2 questions is yes....and yes
Old 04-22-2012, 08:48 AM
So the 1-2 kit will only improve my shift quality?
Old 04-22-2012, 11:34 AM
rick 427's Avatar
It will,as well as improving oil flow along with the firmness of the shifts..thats assuming that the trans is in good working order before you install the kit... ....It's a very good kit....you will have full manual control with the trans...and if you just leave it in D..it will shift automatically.
Old 04-22-2012, 03:15 PM
Ok thank you
TH350 reprogram kit questions lngliv3 Transmission - Rearend 2 11-07-2009 10:39 AM
TransGo Shift Kit vs. Reprogramming Kit Regal Beagle Transmission - Rearend 13 09-01-2008 10:30 PM
Transgo 700 2-3 kit happydad Transmission - Rearend 1 08-18-2007 07:12 PM
transgo kit pink63impala Transmission - Rearend 8 03-23-2005 05:41 PM
transgo shift kit swoodard23 Transmission - Rearend 1 01-18-2003 08:22 PM
