transgo shift kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2006, 03:01 PM
transgo shift kit
hi need a copy of instructions for transgo 400-2 shift kit, i have a kit with no instructions can any one help
Old 01-13-2006, 06:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
TransGo will fax instruction sheets to you if you cal and ask. Some distributors of TransGo products will do the same.
Old 01-13-2006, 07:44 PM
73oldsman's Avatar
http://www.transgo.com/
Old 01-14-2006, 04:46 PM
I called them once before and they were more than happy to fax over the instructions.
700r4 shifting problems with transgo kit mb9900 Transmission - Rearend 18 08-14-2005 09:20 PM
Transgo Shift kit "stick mode" 700r4 eliotmansfield Transmission - Rearend 11 05-03-2005 09:22 AM
What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 AngliaBob Transmission - Rearend 3 04-24-2005 12:25 AM
TransGo 700 Performance Shift Kit Problem edge Transmission - Rearend 1 08-02-2004 01:47 PM
transgo shift kit swoodard23 Transmission - Rearend 1 01-18-2003 09:22 PM
