TransGo shift kit drill bit size? t-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2011, 08:57 PM
prettyboyced's Avatar
i was wondering do anyone knows the size of the drill bit for a transgo shift kit i lost the drill bit that came with the kit its a lockup turbo 350 transmission thanks
Old 01-22-2011, 01:10 AM
CosmikDebris's Avatar
Last journal entry: 1974 S&W
http://www.transgo.org/
Old 01-22-2011, 08:13 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Is this the kit with or with out the separator plate that is between the valve body and trans case?
How firm do want the shifts? A .125 drill bit for the shift holes is good on the street... larger drill bit at .145 will provide firmer shifts.
transgo shift kit question about 2 tomthecomic Transmission - Rearend 2 07-28-2008 10:02 PM
Transgo Th350-3 shift kit Marcus Transmission - Rearend 3 04-06-2008 07:59 PM
transgo shift kit steve baden Transmission - Rearend 3 01-14-2006 03:46 PM
shift kit experience(transgo)? swoodard23 Transmission - Rearend 5 01-19-2003 02:37 PM
transgo shift kit swoodard23 Transmission - Rearend 1 01-18-2003 08:22 PM
