Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TransGo Shift Kit vs. Reprogramming Kit
Old 08-28-2008, 10:22 PM
kleen56's Avatar
kleen56 kleen56 is offline
shift kit and reprogramming kit is the same thing. The shift kit basically reprograms the shift pattern of the transmission by redirecting the flow of fluid with the use of a pattern, springs and a ball bearings. Some guys swear by shift kits and most transmission builders claim they are a waste of money and a transmission can be built to run better than with a shift kit. Trans Go is well known and one of the best kits available. B&M is another option. I'm not running a shift kit in my C4 transmission and it hits pretty hard without it. I have run them in the past and it will definitely make the tranny hit harder and crisper on shifts. You can even program the tranny for manual shifting.
