Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TransGo Shift Kit vs. Reprogramming Kit
Old 08-28-2008, 11:04 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by Regal Beagle
I am wanting to add a stage 2 kit to my SBC Regal 200 4R but I am confused as to the difference between a shift kit and a reprogramming kit.
Do I need just onre of these or both to a\maximize performance?
The shift kit usually just has a few drill bits & maybe a spring for enlarging seperator plate holes. The reclibration kit has shift kit contents plus large TV & Low/Reverse boost valves, valve springs, servo spring, modulator spring etc.. much more complex and the one you should get.
Tip, don't use the washers on the servo pin or use the tight wound spring on the 1-2 shift valve.
2004R-HD2kit if you plan to stay with TransGo products.
