Transgo T-350 stage options - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2013, 09:00 AM
After alot of hours googling I decided to go with the Transgo 350-1-2 kit.
Seems like Jakeshoe covers alot of different forums hopefully ill catch him here! I came across a very detailed post about this topic and now I cant find it!
Problem one is the instructions for this kit is one sheet of paper with little detail. I have downloaded and watched a very "dated" video from Transgo that I feel will makeup for the lack of detail in the instructions. A few questions about the video vs instructions.
1. The Red vs Orange spring. The video uses the orange spring, the narrator calls it the street/strip spring. The paper instructions calls it "Competition only" and the red spring "hardworking & street cars". Im no gearhead, most of my mechanical work requires books and google! What are the pro's and cons of these two springs. Is this the step that could cause a more violent shift? I can never find responses on the net about how the felt about the red spring vs orange spring in there cars.
2. There are steps with a gold spring for modulator( I have decided to not use) and governor springs that was not in the video. It comes with 2 yellows, white and a blue spring. Passenger & light trucks 2 yellows and 4wd white and yellow. I guess the blue is a in between for custom shifts. Should I go ahead and replace the stock springs with two yellows at first?
Little background on the car - 68 Camaro with a mild 350 - stock converter im sure - 12bolt rear. It use to have a pretty agressive th350 tranny when I first aquired the car, would chirp the tires going to 2nd and a occasional 3rd gear chirp. I dont know what was in it. It went out on my years ago and had to replace it fast do to being a daily driver at the time. This tranny is smooth, you feel nothing as it shifts. Today the car comes out 1 or 2 times a month weather permitting and would like to bring the tranny to life(make it a little more fun) if you know what i mean!
I have read posts recommending drilling holes for firmer shifts with this kit. Im not sure what everyone is talking about. A picture says alot for me lol.
thanks!
Old 09-06-2013, 09:03 AM
I feel like a idiot I already made a similar post on this site. Sorry admins! Thought I was on a different forum.
Old 09-06-2013, 06:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what kind of firmness on the shift do you want? Please dont answer with : medium
Old 09-06-2013, 07:41 PM
Want to feel it change gears. Nothing like the B&M stage 2 kits I hear about though. What kind of difference to you suppose I would get between the red and orange springs with just the kit no drilling modifications?
Old 09-06-2013, 08:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Use the red PR spring , leave plate alone.
Do not change the governor springs
Do not install the gold spring on the modulator valve
Shift feel willl also be determined by tire size, gear ratio , converter stall.
Old 09-06-2013, 09:24 PM
Sounds like a plan, Ill post a update when its finished. Why leave governor springs original? Just curious
Old 09-06-2013, 09:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
It is a known starting point for shift timing. Yellow springs, will cause earlier shifts. If you check the OEM springs, one should be slightly lighter than the other if they are OE
See where shifts are at after v-body mods.
Stiffer gov springs = earlier light throttle shifts
Old 09-07-2013, 03:23 PM
Job done. Normal driving speeds 1-2 seems the same. Im thinking previous owner of dead tranny must of had a b&M kit. WOT it will bark the tires going into 2. Playing with the manual shifting it does change quicker, more responsive.
I think if the orange spring would of caused firmer shifting I probably would of went with that over the red. Anyrate not taking all that apart again just to try the orange spring!
Old 09-25-2013, 01:16 PM
hi! i use the orange spring in all of my performance th 350 rebuilds no hard shifting complaints!
Transgo 1-2 shift firmness T-350 Saito Transmission - Rearend 2 01-24-2013 08:36 PM
TransGo shift kit drill bit size? t-350 prettyboyced Transmission - Rearend 2 01-22-2011 08:13 AM
Transgo 1&2 for t-350 misterj Transmission - Rearend 4 07-08-2009 08:21 PM
TransGo 350-3 Questions... aberenz Transmission - Rearend 3 05-25-2009 11:21 AM
TransGo Reprogramming Kit 350-1&2 Woes rdege Transmission - Rearend 6 06-03-2007 06:35 PM
