Transgo Th350-3 shift kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2008, 10:44 PM
Just got my Transgo shift kit for the TH350. It is the version that converts the valve body to full manual shifting...no automatic shifting. Looks fairly straight forward to install however it is not clear whether I should discard all check balls or leave them in. I actually throw these away when I planned on just buying a aftermarket manual valve body. Has anybody installed this particular kit and did you include the check balls. I know in the other kits for the Th350 new check balls are included in the kit but not the 350-3 so I'm assuming it is ok to omitt them.
Old 04-05-2008, 11:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that would be an incorrect assumption.
the instructions I have in front of me are clear about using check balls and the new kits I use all include new check balls.
At the very least the check ball near the modulator valve must be used or very low pressure will result.
Old 04-06-2008, 12:29 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Listen to Crosley. I used a TransGo kit in a T-400, used check balls and a new separator plate I had to drill for shift harshness.
Semper Fi
Old 04-06-2008, 07:59 PM
Thanks a lot...I was going to leave these out. I guess it's just missing from the kit. There is a diagram showing where these check balls are located but nothing in the kit. Guess I'll have to call Transgo in the morning to have them send me the missing check balls.
What will a TH350 Handle? Many Th350 Quetions, Shift kits? Warrant Transmission - Rearend 2 12-18-2005 09:46 PM
need AOD shift kit advice murrsue Transmission - Rearend 5 09-16-2005 09:04 PM
Transgo Shift kit "stick mode" 700r4 eliotmansfield Transmission - Rearend 11 05-03-2005 08:22 AM
installing shift kit Echofive Transmission - Rearend 2 10-09-2004 11:01 AM
TransGo 700 Performance Shift Kit Problem edge Transmission - Rearend 1 08-02-2004 12:47 PM
