transmision / rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2007, 12:47 PM
hi my name is jazzman: i have a 1959 plymouth savoy 6cly.[ flathead ] with a standard transmision. my question is should i go with something like a hemi/727 tranny,and a common rearend? or should i go with a less beffy motor like a 340 or a 360 /and something like a standard or automatic tranny and perhaps a common rearend? what do you all think?
Old 07-28-2007, 02:08 PM
327NUT's Avatar
Hi and welcome.....your parents named you "Jazzman"???? Your build up question can be answered very easily.....how much money do you have? Granted A Hemi/Torqueflite would look great but VERY expensive. Now if you have access to an original 331/354/392 that you can have rebuilt in a fairly stock mode with a little more cam then have at it.
Again it all depends on how much money you have to spend, the more engine you have, HP wise the more you will have to beef up the rest of the car. Don't know what you mean by a "common rearend" but I would just look for an 8 3/4 Mopar rear.
My budget would lead me to an old Motorhome with a 440/727 combo that you could probably pick up very cheap. Most of these are fairly low mileage. I would'nt go below a 383 for your heavy car, cost too much money to make enough HP to get it down the road. Good luck
Old 07-28-2007, 02:29 PM
techinspector1's Avatar
Wiki Edits: 326
Posted by 327nut:
"My budget would lead me to an old Motorhome with a 440/727 combo that you could probably pick up very cheap. Most of these are fairly low mileage. I would'nt go below a 383 for your heavy car, cost too much money to make enough HP to get it down the road. Good luck"
Good advice.
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 10:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
Rearend clunk briz Transmission - Rearend 8 09-11-2005 07:14 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 08:04 PM
