Transmision will not engage any gear! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2012, 11:28 PM
Ok guy, I really need some help here. Im trying to move my mustang for the first time in about two years. I just installed the driveshaft after having swapped to a C6. The shifter will move freely in all gears but the car will not move at all. It starts great and sounds great. I prefilled the new TC and have near 10qts filled inside. The manual calls for 12.5.... Can this be the problem? I will of course add new fluid tomorrow but if this does not fix the problem please post any other suggestion. This transmission worked perfect before.
I made sure the TC was fully engage and the transmission bolted to the block easily, I was as careful as possible with everything. The yoke crosses my mind also as it is not splined fully to the end but it does engage the output shaft a few inches deep. There is more play than I would like but I know its engaging the shaft. Also you can push the car in park.. I have no clue whats going on at all. Please help me out...... Thank YOU!
Old 01-19-2012, 06:51 PM
Did you make sure the shifter was actually moving the gear selector at the transmission?
Th350 can't manually engage 1st gear Viciouscamaro Transmission - Rearend 2 11-08-2011 08:22 PM
C-4 Won't engage butch27 Transmission - Rearend 3 08-04-2009 10:02 PM
TH350 Transmision? a-ray Transmission - Rearend 1 12-01-2007 11:49 PM
AOD mustang transmision 63galaixeguy Introduce Yourself 3 10-04-2004 06:37 AM
700R4 won't engage in any gear Camaro'67 Transmission - Rearend 3 04-29-2003 05:42 AM
