-   -   Transmision worries th350? (http://www.hotrodders.com/forum/transmision-worries-th350-102885.html)
bonanza 11-20-2006 01:57 PM
My 78 Chevy transmission has 13 bolts in it's pan and is nearly square with one corner shampherd. I think it's a th350. It slips going into 3rd gear and while driving in second what should i do?
briscoe 11-20-2006 03:51 PM
Transmission worries th350?
I'm not quite sure what your asking. The 350 does have 13 bolts for the pan.
The direct clutchs apply in 3rd,does it also slip in reverse[directs apply in rev as well].
I want to help you,but slipping in 3rd is not usually something simple.
It sounds like trans has given up the ghost.
Are you capable of working on this,if so I will be glad to help you thru this site.
