Transmision worries th350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2006, 12:57 PM
My 78 Chevy transmission has 13 bolts in it's pan and is nearly square with one corner shampherd. I think it's a th350. It slips going into 3rd gear and while driving in second what should i do?
Old 11-20-2006, 02:51 PM
Transmission worries th350?
I'm not quite sure what your asking. The 350 does have 13 bolts for the pan.
The direct clutchs apply in 3rd,does it also slip in reverse[directs apply in rev as well].
I want to help you,but slipping in 3rd is not usually something simple.
It sounds like trans has given up the ghost.
Are you capable of working on this,if so I will be glad to help you thru this site.
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 09:45 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 11:56 AM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
th350 low roller clutch and 700r4? Tissue Transmission - Rearend 4 05-16-2004 10:23 AM
