Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - transmission
Thread: transmission
Old 03-23-2002, 11:28 AM
Studebaker Studebaker is offline
Contact "Wilcap" engineering. They make this type of adapter for either torqueflite, powerglide 350/400 or 700r4. Also a note, you will have to get a oil filter adapter because the stock 392 oil canister is much to large to fit in the frame of the 32. These also can be made out of a oil filter flange assembly off a 360/390 Ford "FE" series engine. GOOD LUCK!
