Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission
Thread: Transmission
Old 09-30-2003, 08:00 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
check the govenor, make sure the gear isn`t broken and etc. pull the stick and look at the fluid, if it`s black and stinks, it means the tranny got too hot and is cooked. number 1 cause of auto tranny failure is heat so adding a cooler is of good benefit. if the tranny was still in the truck I would have said to check the TV cable that runs from the tranny to the throttle body or carb, if it`s out of adjustment, broken or off the tranny won`t shift.
