Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2003, 08:35 PM
Transmission
IVE JUST RECENTLY PICKE UP A 51 MERC ITS BEEN COVERTED FROM STANDERD TO AUTOMATIC . THIS IS MY FIRST MERC AND
FOR SOME REASON I COULDNT FIND WHERE TO CHECK MY TRANS FLUID OR WHERE TO ADD IT ANY HELP WOULD BE GREAT THANKS
Old 08-09-2003, 08:40 PM
adtkart@aol.com
Welcome to the board. You are obviously new, as you are yelling(using caps).
To start, you need to supply some information to get some. The vehicle was changed to an auto trans, fine. What kind of trans? Most auto trans have dipsticks for checking the fluid. The dipstick should usually be on the right side of the engine compartment near the firewall.
Hope this helps.
Old 08-09-2003, 09:10 PM
transmisson
your right im new thank you for your reply adtkart I really dont know what trans I think it was done years ago and th find where to check it ere doesnt seem to have a dipstick It might be gone and thats why I cant thanks anyway Ill keep looking
Old 08-10-2003, 07:40 AM
adtkart@aol.com
Do you have any idea what year the trans came from, as in newer or possibly the same period of the vehicle? Can you check the shape of the trans pan to help identify the trans? Is it the original engine in it? Just trying to get some info to go by. Also check at the trans on the front near the bellhousing. You should see where the tube runs from or to.
Old 08-11-2003, 01:37 AM
thanks
thank you adtkart for your time I finally foud where it is
with a hint from a friend the access was inside the car under the carpet just pulled it back and there it was once again thanks for you time
Old 08-12-2003, 11:34 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
That must be one OLD auto trans! The only one I can think of that would have a location as you describe would be the original GM Hydramatic. I know Ford bought some for Lincons, but don't think they used them anywhere else until they came out with their own auto (actually a joint venture with Studebaker and Borg Warner) in the mid 50s (about 1954). I've messed with some of the late 50s models and they all had regular dip sticks, but it's possible the first ones didn't.
