transmission for 301 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2011, 07:03 AM
i have a 79 pontiac 301 in my trans am with the factory th350 3 speed in it.. i was wondering what would be the best transmission/rear end gear for it? i also have the factory rearend gears as well
Old 11-30-2011, 10:31 AM
Well what do you want to do with the car? 'Best' depends on the application. a TH350 and some 3.55:1 rear gears makes a good all around driver.
For a little more money, a quality built and adjusted 700-r4 with some 3.73:1s makes a great all around car.
Or a brand new muncie 4speed and whatever gears you want; there are gearsets to accomodate everything from 3.08s to 4.88s
Old 11-30-2011, 12:32 PM
joshp83's Avatar
owner of Prices Garage
the th 350 is good are u sure its not a th200 though some 301 tas had them but i think it was 1980 like the last post stated 3.55 is probley the lowest u want to go with a 3 speed a 200r4 or 700 would be a nice swap though
Old 11-30-2011, 03:18 PM
The best trans to use? Any one that comes with a 455 Pontiac bolted to it already.
OK, seriously, given the wimpy 301, I would suggest a 200-4R. It's nearly a bolt-in (you need to adapt a TH400 crossmember from an early 2nd gen F-body, but otherwise your existing driveshaft works fine). The 200-4R has a 2.74:1 first gear vs. 2.52:1 for the TH350. This alone will help off the line acceleration with your stock gears. Even better, the 0.67:1 fourth gear will let you run steeper rear gears while still lower freeway RPMs. Most 200-4Rs came with the dual bolt pattern bellhousing, so it bolts directly to your 301.
GMC transmission jamn50 Transmission - Rearend 4 10-26-2006 09:15 PM
transmission ant Transmission - Rearend 1 08-06-2006 09:39 PM
Help: Transmission ID gbowne1 Transmission - Rearend 5 07-28-2006 05:03 PM
Transmission RICHARD GLADDEN Introduce Yourself 0 08-25-2004 04:05 PM
transmission slimmshady4 Transmission - Rearend 1 05-22-2003 07:27 AM
