transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2002, 07:51 AM
Post transmission
i bought a used TH350 now i have it installed in my camaro.....but 2nd gear seems to slip.....also slips at other times....is it possible the bands are stickin cause it sat in the junk yard....if so can the bands be adjusted and how?
Old 05-09-2002, 09:59 PM
taz taz is offline
New Member
Post
Mustang Smasher, The Bands are not adjustable on the T.H. 350. They are applied by a servo in the Trans. I hate to say this, but maybe You should pull the Pan, and see how much Crap is in the bottom of it. Any amount over say, a couple of Tablespoons, is too much. Look for Brass Cuttings, lots of Dark colored Material{Clutch Plate, Friction Material}, and other odd Crap.
If there is alot, Pull and Gut the Trans, You will be further ahead to Rebuild now, before It leaves You Stranded Somewhere.
