transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2002, 03:32 PM
Question transmission
I am buliding a 70 Monte Carlo and when I am ready for a new transmission I want to use something other then 350.I also have a 94 chevy truck with a auto transmission that has overdrive I think can I put in a transmission like that in the Monte and if I can what do I have to do (Will it bolit up and do I need to run wire for what ever they use thats not in the monte I am a long way from doing the motor and transmission but like to start to look for what every I will need to do the change datadave49 @rcn.com <img src="confused.gif" border="0">
Old 06-18-2002, 07:36 PM
Tom Tom is offline
Post
I think but not real sure that the 95 tranny is a complete computer controlled unit and wont work on the 70 without the whole engine package from the truck. I would get a 700R4 or 4L60E where you could hook it up with a few wireing tricks
Old 06-18-2002, 07:49 PM
Post
Thanks Tom for that info I did not want to go with the computer controled tranny.The 700 sound like the way to go but what is this 4l6oe do you know what the differance is between them
Old 06-20-2002, 01:39 PM
Post
i don;t think the 94 would have the 4l06E. jstu check. get under it and look. i know the 700r only has two wires goign to it i think so if the trans has mroe than that i guess its the 4l06e (cvorrect me if i m wrong).... the 4l06e is just the same as teh 700r i believe except its computer controlled
Old 06-20-2002, 04:10 PM
Post
So what you are saying is I should have two wires on my truck tranny if I have more its a 4l60e I will check this weekend and get back to you
Thanks
Dave
Old 02-26-2003, 08:14 AM
Post
here is some useful info. the 700r4 and the 4l06 are the same transmission. the 4l06e is computer controlled version of the same thing. previous posts have said that you dont want to use the 4l06e. out of all those transmissions, that is the one that i would use. there are lots of companies that make performance upgrades for these tranmissions as well as the hardware that you need for it to work. if you are looking to do a motor tranny swap, then check ebay for a motor and a tranny out of a car like a late f body or a corvette. there are lots out there that have everything that you would need. email if you want more info. i also do have some more info if you want to go with the 4l06. you can use any one of these transmissions with your car.
[ February 26, 2003: Message edited by: Silver ]</p>
Old 02-26-2003, 09:54 AM
Post
Actually, the 94 will have the 4L60E. They switched completely to the electronic version in 1993. I drive a '93 and before that was a '94....both 4L60E's.
Old 02-26-2003, 10:18 AM
Post
A 4L60E and a 700R4 are the same trans.One is electronic the other is manual.If you run the 700 make sure you hook up the detent cable (passing gear) or the trans won't work.If you use the 4L60E b&m makes a control box for it to work.
Old 02-26-2003, 04:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
Well,,,,,,, the 4L60/700R4 tranny has an electrical plug on the drivers side. A square connector with 4 holes.
In early 1993 there was non electronic 4L60 trannys. They had the above mentioned square plug OR round 5 pin plug on the drivers side.
The 4L60E electronic tranny was introduced in 1993 and it has a round plug about 1.25 inches in diameter on the passenger side on the tranny.
At the bottom of my web page:
http://www.geocities.com/crosley_az/700id.htm
There is a picture of a 4L60E tranny if you wish to look. The pictured tranny is the 3 piece case design, where the bell housing unbolts too. The case connector on the 2 piece case 4L60E is in the same location.
Tony
Old 02-26-2003, 08:29 PM
former member of HR.com
Post
Tony! Thats a really nice web page. Good info and some cute pics...specially the mutt! The 700R4 info is good to know about, I bookmarked it. thx. K
