Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2003, 08:12 PM
Post Transmission
I have a 1986 chevy s-10 with a 350 V8 in it. We origionally put a TH700R4 tansmission in it and it went out. The automatic just wasn't winding out as tight as i wanted it to off the line when it was shifting, so bought a muncie M20 4-speed. I know i need to change the rear end gears because of the 1.00 4th gears ratio in the 4-speed.I was wondering what the best gears to put in the rear end?
Old 01-12-2003, 08:29 AM
Post
I would run the gears you have and see what they are like if you want more getty up off the line go numerically higher ie.. 3.08's to 3.73's but just remember that your RPM's will be higher on the highway! Zach
