transmission column linkage- 700r4 to a t-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2008, 09:08 AM
I plane on using a summit th350 in a 88 2wh drive Chevy pickup originally it had a 700r being that the 350 and 700 are related except for overdrive will the column shift work with just a gear indicator change?
Old 01-02-2008, 12:27 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Yeah it will work but the indicator position will be off. even if you change it to a 3 speed indicator it probably wont line up.
Header collector in way of column shift linkage Warrant Engine 4 08-29-2006 01:26 PM
350 lock up transmission str8_57 Transmission - Rearend 7 02-13-2006 07:28 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 12:14 PM
Turbo 350 to a '94 700R4 or 4L60 classic_chevy_guy Transmission - Rearend 9 01-27-2004 10:32 PM
Ram Jet 350 with 700R4 Bill Ford Engine 1 10-25-2002 08:03 PM
