Transmission Conversions for Flatheads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2006, 03:59 PM
I am currently working on building a 1936 Ford 5 Window Cpe Resto-Rod. I am using a 49-51 Merc 8-CM Engine. I have also acquired a Ford 9" rear end I believe came out of a Granada. What options do I have for putting an automatic between the 2? Also who makes conversion kits to make this work? I also do have the original Mercury Belhousing for this engine. Also where do I locate an adapter kit for mounting which ever automatic I will be using in the original 1936 Ford Frame?
Old 10-06-2006, 04:10 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Check Speedway Motors on line, they have a kit to connect a flathead to a C4 automatic...
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 11:00 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 10:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 08:43 AM
