pic. . . |
If the Torque Converter is shot, I will still have a pressure ready?
If the Torque Converter is shot, can I only replace it, or do I also need to get the tranny rebuilt? Thanks, Daniel. |
The torque converter has nothing to do with pump pressure unless the snout is sheared off or something. (the TC snout drives the pump inner gear) A pressure check is one of the first things to diagnose a problem with an auto trans... |
Park/neutral - 55-75 psi
Low and D2 - 85-110 Drive - 60-90 Reverse - 85-150 1000 rpm brakes applied. |
Spring arrived yesterday and I got the 1st gen bug, I getting ready to take it out, especially that the 2010 are about to come out I cannot be Camaro less.
I finally took the the time to hock-up a gauge on the transmission side port this afternoon. I have 60psi in neutral and more when I put in in speed. I can now conclude that the transmission front pump is good and that its my Torque Convertor that is defective. It now time to shop for a replacement Torque Convertor... What would you recommend (Make, Model and RPM), I have a TH-350, 3.73 Gears and 26.1" tires? Is it Ok to replace the torque without rebuilding the transmission? I will of course change the tranny oil. Thanks, Daniel. Last edited by FBody; 03-21-2009 at 03:23 PM. |
It sounds like you broke the sprag in the converter. When you pull it apart remove the converter from the trans then reach with your finger down in the hub of the converter and you'll feel a splined portion and try to rurn it both clockwise and counterclickwise. It should only turn in one direction if it does turn both ways the sprag is bad. This indicative of to much power and not enough sprag. Buy or have this converter rebuilt with a mechanical diode or what is called a spragless converter and eliminate any further trouble. Good Luck!
| 86 Chevy k10 4x4 700r4 , converter question | frontierstorm | Transmission - Rearend | 0 | 05-28-2008 11:02 PM |
| Transmission swap: TH250 to TH350 Torque converter issues. | 35oldstruck | Transmission - Rearend | 5 | 05-21-2008 03:43 PM |
| Help tuning 383 for street use | strokey | Engine | 34 | 04-11-2008 05:51 PM |
| Torque converter leaked out fluid?? | 84Z | Transmission - Rearend | 2 | 08-13-2006 09:32 PM |
| tricks for motor/transmission alignment? | killerformula | Engine | 24 | 07-03-2004 01:00 AM |
