Transmission cooler or A/C condensor coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2008, 08:44 PM
I've been doing a little brain storming, and i cant think of a good place to mount a tranny cooler. Now just hear me out before you say your oppinion.
My car used to have A/C it doesn't any more, i removed all of it and blocked off the fire wall. I still have the condensor coil laying in my garage. I'm thinking of getting rid of my flex fan, and installing a dual 14" electric fans with a thermostat. each fan is supossed to be pulling 1600 cfm so i think it's keep my radiator nice and cool, esspecially cruising. my ? is if i clean that A/C condensor out really good, say flush it with gas, then water, then purge it with tranny fluid, could i re-install it back in front of the radiator like it was stock but have it as a transmission cooler instead? what do you think guys, remember its just a thought at this point.
Old 08-26-2008, 09:34 PM
Wiki Edits: 27
I did it
the problem i had was the tubing wore thru the rubber hoses, I just cut them with a hack saw. didn't debur or smooth the ends
Old 08-26-2008, 10:55 PM
SSedan64's Avatar
Clean it good with Brake cleaner & compressd air. May cool too good in winter but you can buy a thermostatic bypass valve from B&M for that. Opens around 180*, below that it returns coolant to trans for fast warm up.
Also you can get adapter fittings with nipple ends for the hose so you don't have to cut the condensor lines.
Old 08-26-2008, 10:56 PM
and
did you fix that problem and did it work ok after that. I'm planning on using all metal lines, no rubber, but if i end up having to use rubber I'll use the highest PSI and temp hose i can find, mabey even some with steel braid or mesh in it.
Old 08-27-2008, 12:12 AM
to thin??
someone told me that the passages may be to thin for tranny fluid to circulate very well and if so it could burn my pump up in the tranny, do you guys know anything about this.? I forced some fluid through it today with compressed air just to see what it would take, it seemed to come through pretty easily. what do you guys think?
Old 08-27-2008, 12:29 AM
SSedan64's Avatar
It's possible it could pose a restriction. Easy enough to check tho', just rig a pressure gauge inline before the cooler and see if you have a pressure spike/rise at idle and 1500-2000rpm. Test without the cooler hooked up first & compare readings.
Most I've used had plenty of flow.
Old 08-27-2008, 02:19 AM
most
you say "most you've used", how many times have you done this. how many were unsuccessful, what were the results?? please share your knowledge/expirience. what kind of car did the a/c coil you used come out of?
Old 08-27-2008, 03:05 AM
SSedan64's Avatar
I've used many over the years. Older GM cars that ran R12 freon. Tried one from an Isuzu that was not factory installed & was too small & factory Toyota & Honda was too small. Seems all the ones with the flat flues were too small.
Old 08-27-2008, 07:24 PM
R12
So do you know what an 82' cutlass supreme would have ran. Did you ever use one from a G body?
Old 08-27-2008, 07:58 PM
SSedan64's Avatar
I have a 80 Cutlass Supreme in the yard. That thing is huge, has two rows of flues/tubes & is as large as the radiator. It's the right type tho', with the round flues/tubes.
Old 08-27-2008, 10:08 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I used the a/c condenser in my 1968 Chevelle for a t-400 trans cooler ... this was many decades ago.
The condenser was the OE unit for the Chevelle.
Old 08-27-2008, 11:08 PM
t cooler
thanks for the info guys, i got a couple nipple ends to screw into the lines that will let me put a hose on it. I will be making that mod as soo as my stall arrives. I won a brand new Dacco today 33-3500 stall, should be to my door within 1-6 bussiness days. I'll let you know how everything turns out. Have a good night.
Danny
T-350 cooler lines.... sexypizzaman Transmission - Rearend 8 06-17-2008 11:50 PM
Transmission cooler Blackhauk90 Transmission - Rearend 4 06-03-2008 04:57 AM
trans cooler tomco550 Transmission - Rearend 1 10-06-2006 03:44 PM
How does a transmission cooler work in a radiator? batman09 Transmission - Rearend 3 09-14-2004 08:49 PM
A/C question Paco Engine 1 06-03-2002 07:01 PM
