transmission cooler line fittings - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-10-2008, 11:43 AM
life is a temporary assignment
I have put AN fittings right in the trans and never had NO PROBLEM.EVER!!Just a AN with pipe treads.
  #17 (permalink)
Old 02-11-2008, 09:53 AM
Wiki Edits: 27
hose fittings
My buddy couldn't find the right single piece fittings so he ended with 2 or 3 pieces screwed together to get the right threads. etc at each end... the info for the single piece is what I will save for when I get that far along on the lakester thanks guys
  #18 (permalink)
Old 02-11-2008, 10:32 AM
I've been looking at doing something like this, too, but I wanted to do it AN all the way. For the fittings in the trans, I think (not sure. Feel free to correct me) that an AN-4 O-ring to AN-6 will be a direct fit for the trans fitting. The O-ring side has straight threads, and the charts I've seen say that the threads are the same size as the straight threads on the stock fitting. I haven't gotten the fittings to try, yet, but I do know that -6 won't fit in the trans.
If anyone wants to see what I'm talking about, I was looking at getting these fittings from Fastenal (PN #424009-131280, $2.46/ea, Steel -6AN to -4AN O-ring adapter).
Like I said, feel free to correct me if I'm off-base, here.
- Mike
  #19 (permalink)
Old 02-11-2008, 12:04 PM
This is a line kit from Jeg's Part # 555-60361 1/4 ''NPT Straight fittings This is for a 350 trans.
  #20 (permalink)
Old 02-11-2008, 12:23 PM
Irelands child's Avatar
Is this what you are trying to do? Ford C4/-4 lines, 24 inch double pass cooler.
Irelands child
air line fittings wisch79 Suspension - Brakes - Steering 4 03-08-2006 05:35 AM
brake line fittings 70Shorty Suspension - Brakes - Steering 3 01-23-2006 08:37 AM
Trans cooler lines which is which atlantis Transmission - Rearend 44 01-08-2006 04:19 PM
transmission oil cooler ffcagle34 Engine 5 11-22-2002 02:40 PM
Transmission Cooler mcbroom Engine 3 08-06-2002 07:59 PM
