transmission cooler line fittings - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2008, 05:38 PM
Hi
I'm installing one of those finned aluminum frame mounted tranny coolers. I am going to run hose from the tranny to the cooler and back (no hard line). My tranny had the fittings in it for a hard line to connect to ,I took them out and put in npt fittings with hose barb ends,I sealed them with yellow teflon tape . The thing is the old fittings had a washer-gasket that bottomed out when screwed in my new fittings don't. Will I have a leak? Is there any pressure on them lines? Or will it be OK ?
Thanks
Old 02-09-2008, 05:57 PM
I had that same question when I did mine. TH350? I put NPT AN fittings, with a little pipe tape, snugged them up and was fine.
Cam
Old 02-09-2008, 06:02 PM
yeh,its a T350 just checking, don't want to work on the car all winter and then have leaks
THANKS !
Old 02-09-2008, 07:38 PM
life is a temporary assignment
I set mine up with all AN fittings.
Old 02-09-2008, 08:19 PM
Wiki Edits: 27
Napa bins
My buddy went to the Napa store and after a couple of try;s by the kid there , they let him go thru the fitting bins and he finally found what he needed
Old 02-09-2008, 09:13 PM
What did he find? All I could find were the npt with hose barb They aren't a n just plain pipe thread. Will this work is what I want to know
Old 02-09-2008, 10:27 PM
It should be pipe threads on the cooler.
Old 02-10-2008, 06:45 AM
It is ,the fittings for the cooler came with it. What I'm talking about is the fittings coming out of the tranny
Old 02-10-2008, 07:15 AM
justold's Avatar
You need 5/16 inverted flare to barbed ,look around the carburetor isle. Leave the fittings in the case ,there're there so you don't crack the case with tapered thread fittings .
Old 02-10-2008, 07:20 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
This is also what I would suggest to avoid crack in the case.
Thread a proper fitting into the OEM cooler line fitting.
Old 02-10-2008, 10:03 AM
OK
I'll have to go look around,I already threaded the npt barbed fittings in I hope I didn't screw something up I was doing what the guy at a local parts store told me to do ,but they don't seem to tighten snug, thats why I was asking if it was right. The fittings that were in the tranny that the original tubing screws into I don't think npt screws into them,or do they?
Old 02-10-2008, 10:35 AM
justold's Avatar
This is what you are looking for, not IPS [pipe thread] for what ever size hose x 5/16 tube .
Push-On Hose Barbs: Push-On Male Inverted Flare
Regular price: $3.88
Sale price: Push-On Hose Barbs: Push-On Female Inverted Flare
Regular price: $2.48
Sale price:
http://www.fittingsandadapters.com/pushosbar.html
Old 02-10-2008, 10:56 AM
Now I'm really confused!!(or just stupid) I have 3/8 hose and the fittings on the cooler are 3/8 barb,but not sure what size inverted flare fitting I need ,and would I get a male and screw it into the existing tranny fitting,or would it screw directly into the tranny? If u could look at the site u recomended and tell me the part number I would be eternally in your debt.
Thank You
Gary
Old 02-10-2008, 11:26 AM
justold's Avatar
IM-6-5 3/8 5/16 4.48 2.24 is the fitting number . These screw into the existing fittings .
Old 02-10-2008, 11:32 AM
THANK YOU VERY MUCH!!!
I will order them today
Gary
air line fittings wisch79 Suspension - Brakes - Steering 4 03-08-2006 05:35 AM
brake line fittings 70Shorty Suspension - Brakes - Steering 3 01-23-2006 08:37 AM
Trans cooler lines which is which atlantis Transmission - Rearend 44 01-08-2006 04:19 PM
transmission oil cooler ffcagle34 Engine 5 11-22-2002 02:40 PM
Transmission Cooler mcbroom Engine 3 08-06-2002 07:59 PM
