Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Cooler Location
Old 04-22-2013, 01:04 PM
sedanbob's Avatar
sedanbob sedanbob is offline
If you are still running hot, you might try adding a fan to the cooler - some come that way so you should be able to buy the fan somewhere. Airflow is important - if you aren't getting flow over the coil, you will need a fan. Derale Universal Remote Coolers with Fan - JEGS
The Following User Says Thank You to sedanbob For This Useful Post:
454 Rattler (04-22-2013)
