Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Cooler Location
Old 04-22-2013, 03:19 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
I find these work so much better then them the flat ones... If the flat ones don't have a fan or mounted up and down I find it hard for the air to past where it needs to pass,,through it... They are good for in front of the Rad, I run ones like this under all my car's with no problems at all..
You can run the one you have,, But if it's laying flat under the car,, Put a fan on it..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
john freitas (08-08-2015)
