Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Cooler Location
Old 04-24-2013, 05:00 AM
Irelands child's Avatar
Irelands child Irelands child is offline
I have an extruded two pass, 24 inch long mounted on the frame rail of my '31. I also have a temp sender mounted in the pan and use a DPDT switch to the engine coolant gauge so I can monitor both with a quick flip of that switch - both run about 180 degrees F on a 90+ day. You can debate location of the sender, but the pan is the easiest for my application. Couple of photos attached:
ID:	73528   Click image for larger version
Name:	Trans cooler.jpg
Irelands child
