Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Cooler Location
Old 04-24-2013, 10:33 PM
406 bug's Avatar
406 bug 406 bug is offline
9.82 @ 139mph
Originally Posted by 454 Rattler View Post
There is a flat trans cooler mounted under my 36 Ford street rod.
I'd like to know just how well these work if mounted flat under the floor with about 3" clearence above the unit. Have any of you checked the fluid temp before and after a cooler mounted likt this ?
Not much room to mount a scoop cause of ground clearence. I don't want it mounted in front of the radiator.
Any ideas ?
THANKS !!
454 RATTLER
Maybe you have room in front or rear fender well or rear axle tunnel. I prefer B&M stacked pate with Virgo fan.
