Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Cooler Location
Old 05-01-2013, 10:54 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Originally Posted by BigMo View Post
Nice setup......I have that still cooler on my trans also (30 Ford Coupe) but wondered about its effectiveness, so got the parts together to add a tube/fin performance style up in front of the rad.....apparently these type coolers do a good job from your report. On the temp sender in the pan, I am getting ready to add a deep pan and like that setup....what or where did you get the bushing to install the sending unit? Did it come as a kit type thing......
If it's an aluminum pan, just drill and pipe tap it for whatever temp sender you want to use. Most gauge companies can supply you with a standard thread sender, O-ring and nut for a steel pan. I had a VDO sender for a steel pan but not a clue as to what happened to it as I didn't use it.
Irelands child
