transmission coolers, what kind and size to get? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2006, 01:35 PM
Hello I have a 1991 olds 88 that I am getting to run better now with the bent rim replaced........vibration to a minimum..........and would like to know what kind of tranny cooler will work best.......is too big not good either.......or just but a big *** one on there and it will not hurt anything...........these trannys in these cars are expensive to rebuild and I would like to make this tranny last......and heat in an automatic kills transmissions so what do you people think
Old 09-05-2006, 10:04 PM
Mechanic
bigger is better
Old 09-05-2006, 10:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the stacked flat plate style cool the best for air to liquid cooling.
Old 09-05-2006, 11:00 PM
predator carb guru's Avatar
Mark Goulette
i like the stacked plate type as well. get as big a cooler that you can fit in your vehicle.........you can never over cool an automatic trans.........
Old 09-06-2006, 12:30 AM
so then I take it I can "tim allen" this thing to the hilt then, good....one note, I do live in ohio it gets down to 10 degrees at times, but I dont think that would hurt it
Old 09-10-2006, 04:28 PM
what is a stacked flat plate style?
Old 09-10-2006, 11:47 PM
ok I bought the b and m cooler from summit, the whole store was on sale so the 42.88 one was 38 something. 70255............just wished I would have drove there earlier...........they must have had another event there.so we will see if that affects my shudder or vibration or what ever I am feeling
Spray Gun Tip Size to prevent orange peel Gro Harlem Body - Exterior 5 03-14-2005 03:57 PM
What kind of rear end does my 64 Impala have? Uber Transmission - Rearend 8 07-17-2004 08:00 AM
What size carb? yosimdisam Engine 8 04-29-2004 07:14 AM
A few changes to 540 hp carcraft buildup... what kind of hp loss? guesstimates please elukas Engine 16 08-07-2003 08:54 PM
