Transmission Cooling Line Fitting - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2011, 10:43 AM
dirty dixon's Avatar
So I have just about got the car back together except I am having a hell of a time trying to find the last piece.
I need to find a source for these fittings:
The Car is a 95 Honda civic ex with auto trans
It is the fitting that threads on to the radiator (19mm) and the other end goes into the rubber automatic transmission cooling line and is held with a clamp.
Napa did have it nor did any of the other local auto shops.
If someone on here has a 95 with auto trans that they are parting let me know.
Thanks Guys.
Old 11-16-2011, 10:48 PM
406 bug's Avatar
9.82 @ 139mph
Honda dealer , radiator shop or wrecking yard?
oil line brass fitting cletusvandamme Engine 3 06-19-2011 04:31 PM
Help with -An fitting to hard line... obengston General Rodding Tech 16 11-23-2010 08:31 PM
Transmission (broken) cooler line fitting extraction 78 monte Transmission - Rearend 1 10-21-2007 02:36 AM
Transmission cooling line pressure 700r4 grumpy1 Transmission - Rearend 4 08-22-2007 08:34 PM
Brake Line - 3 way fitting, one way only? BIGSKY Suspension - Brakes - Steering 2 11-17-2005 02:30 PM
