Transmission cooling line pressure 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2007, 08:41 PM
Guys, what would the cooling line pressure on a 700r4 be at operating temp., and what would that temperture be?
Also could you use rubber lines in some places in routing the lines. Maybe high press fluid hose. I am thinking from the first 6-8" of steel line, and the rest be rubber. Is this a bad idea?
Old 08-18-2007, 07:26 AM
Crosley's Avatar
Wiki Edits: 1659
rubber hose is bad idea. IF you run rubber hose it must be a hydraulic type hose at proper rated PSI
Cooler line pressure can run 25 - 80 psi depending on the trans setup - shift kit and internal modifications
Old 08-18-2007, 07:27 PM
Thanks Crosley, That answers my questions. Its a tight place and to be able to work the lines around things would be tough. I wanted to use about 6-8" from the trans. and then work the rest with Hydraulic hose up to the radiator, then go back to steel. Thanks a lot.
Old 08-22-2007, 06:34 PM
From an auto-parts store power steering return line would be what to look for (should have the press & temp rating on the hose). Good auto parts stores will sell it by the foot on a spool. Make sure it is shielded from exhaust heat and inspect/replace it periodically.
Old 08-22-2007, 08:34 PM
Thanks Triaged, I didn't think of that. It is probably cheaper than hydraulic
hose too. I will check it out.
700r4 low pressure hudsonman Transmission - Rearend 3 11-06-2006 09:49 AM
700r4 transmission problem msmaddog Transmission - Rearend 2 10-14-2005 09:54 PM
Fuel Pressure DoubleVision Engine 18 05-31-2003 05:49 AM
700R4 transmission beetle9 Transmission - Rearend 9 09-17-2002 03:02 AM
SBC Cooling bypass line question HotRodF100 Engine 2 06-15-2002 06:50 PM
